Mirrored components in assembly
Does anyone know if it is possible to mirror a single part with in a assembly without SW wanting to create a file for the mirror?  I want to use the mirror in a similar fashion to component pattern but my pattern has to be mirrored.  It would be easy if I could just mirror the parts I wanted about a plane the same way as you can mirror features at the part level.
RE: Mirrored components in assembly
Insert/mirror components
Select component and plane.
Chris
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 10-27-06)
Cool thanks for the info, I had tried that before and it wasn't working for me.  But I've notice if I just select the components and don't put check marks in the boxes beside them everything works fine.  As soon as I check them, I am prompted for new file names.
"... without SW wanting to create a file for the mirror?"
Not if it is a true mirror of the original part. The Insert > Mirror Components function has an option to create a mirrored instance of a part in an assy, but it will not be a true mirror ... just a rotated instance of the same part.
A true mirror of a part will be an associated but separate part from the original, and as such will be automatically saved as a separate file.
cheers
CorBlimeyLimey, how do you make the instane of a part in the assy option available?  I see it there but I cannot click it on.
The instance is created when the grey box beside the selected part to mirror is left unchecked.
A true mirror (LH/RH part) is created when the grey box is checked.
cheers
Ah, perfect thanks a lot!
