How to find .msg file?
Hi Guy,
I have some simple questions. Where can I find the .msg file? I can find only .dat and .inp files in my working directory. Where can I check the resultant applied loadings in my model after the (processing)job is done. Thanks. BTW, how can I change the scale factor for the displacement in contour (ABAQUS/CAE in ver. 6.6). I tried to find them in the manual, but nothing. Thanks a lot.
RE: How to find .msg file?
1. go to menu Options
2. Click on "common" option
3. then you will find "deformation scale factor"
I found the .msg file also. It's in the same directory. But, where can I check the resultant load in my model? I just want to ensure the applied load is correct. Thanks.
corus
we can check the sum of the reaction force in all nodes in order to make sure the applied resultant forces/pressure is correct.
