RSView question about strings
I need to read from two different integer files and combine the results into a display, do some math to the result, and send the final result back to another integer. The problem starts with the "combining" - I don't want to add them, just combine them. Example, if I have a 6 in N9:1 and a 3 in N9:2, I need the final result to be 63 (not 9).
I was able to do this by creating two string integers that read from the two integers and combining them with an expression (N9:1)+(N9:2) to display in a numeric display (which seems to work fine - don't know if I'm breaking any rules here)
My problem now is that I need to perform a calculation on the displayed result and send it to, say, N9:3 (Actually, I need to do several calculations with that number and sent the various results to individual integer files)
Any help along these lines would be greatly appreciated!
Wolf
Wolf
RE: RSView question about strings
Thanks!
