LM6 Aluminum S-N Curve / Goodman Diagram
I am finding it very difficult to get hold of this information. Does anyone know where I could obtain an "endurance curve" for pressure die cast Aluminum LM6. Not a limit, but the curve plotted from empirical data from a R.R.Moore test. I already know it is 70 - 100MPa at 5x10^8 cycles. But I need the curve, so I can predict the stress level at much lower cycles.
Alternatively, I have been able to plot such a curve before for steel, from formulae in "Machine Component Design" by Juvinall:
Sn = S'n * Cl * Cg * Cs * Ct * Cr
Sn = Endurance Limit
S'n = 0.5 * Ultimate tensile strength (for steel)
Cl = Load factor
Cg = Gradient Factor
Cs = Surface Factor
Ct = Temperature Factor
Cr = Reliability factor
If anyone has any of these factors, that would also be greatly appreciated.
Thanks!
Cl = Load factor
Cs = Surface Factor
Thanks!
