passing allocatable arrays to subroutines
I am trying to pass allocatable arrays declared on the main  program to a subroutine and use this data inside the subroutine and then send it back to the main program. How do I declare the arrays inside the subroutine?
RE: passing allocatable arrays to subroutines
here's a simple example I found on the Net, for Fortran 90
module numz
  integer, parameter:: b8 = selected_real_kind(14)
  integer gene_size,num_genes
  integer,allocatable :: a_gene(:),many_genes(:,:)
end module
program darwin
    use numz
    implicit none
    integer ierr
    call set_size()
    allocate(a_gene(gene_size),stat=ierr) !stat= allows for an error code return
    if(ierr /= 0)write(*,*)"allocation error"  ! /= is .ne.
    allocate(many_genes(gene_size,num_genes),stat=ierr)  !2d array
    write(*,*)lbound(a_gene),ubound(a_gene) ! get lower and upper bound
                                            ! for the array
    write(*,*)size(many_genes),size(many_genes,1) !get total size and size
                                                  !along 1st dimension
    deallocate(many_genes) ! free the space for the array and matrix
    deallocate(a_gene)
    allocate(a_gene(0:gene_size)) ! now allocate starting at 0 instead of 1
    write(*,*)allocated(many_genes),allocated(a_gene) ! shows if allocated
end program
subroutine set_size
    use numz
    write(*,*)'enter gene size:'
    read(*,*)gene_size
    write(*,*)'enter number of genes:'
    read(*,*)num_genes
end subroutine set_size
Here is another example for F95.  It won't work in F90.  This allocates within the routine but you can equally do it outside.  All you said you were interested in was the declaration.
CODE
module BoxMod
contains
   subroutine BoxCreate (blist, bsize)
      ! Declare an allocatable parameter
      integer, allocatable, intent (inout) :: blist(:)
      integer, intent (in) :: bsize
      integer :: b
      allocate (blist(bsize))
      do b = 1, bsize
         blist(b) = 0
      enddo
      return
   end subroutine BoxCreate
   subroutine BoxDelete (blist)
      deallocate (blist)
      return
   end subroutine BoxDelete
end module BoxMod
program main
   use BoxMod
   integer, dimension(:), allocatable :: alist
   integer:: amaxi
   parameter (amaxi = 20)
   call BoxCreate (alist, amaxi)
   do i = 1, amaxi, 1
      alist(i) = i * i
   enddo
   do i = 1, amaxi, 1
      write (*,*) alist(i)
   enddo
   call BoxDelete (alist)
   stop
end program main
You do it the same as you do any arrays.   From the perspective of the Subroutine,  the arrays it receives might as well be ones that were declared in the main routine without the allocatable attribute.  There's no need for you to use modules or anything else to handle this situation.  Keep in mind,  we are talking about simple arrays of standard data types here, ie. Integer, Real, Character, etc.  This doesn't apply to arrays of user defined Types.
Dan   smile
www.dtware.com
