Carlson Civil Package
My company is currently evaluating the Carlson Civil package as an integrated civil design tool. We are under the impression that with this software and others such as; HydorCAD, PodPAC, Flow Master and Culvert Maseter that we can suffice all of our current design needs.
Does anyone have experiance with the Carlson software and whether they are aware of any limitations? Can this software be used strictly for hydraulics and hydrology without major setup time involved?
DCN
DCN
RE: Carlson Civil Package
I believe Carlson will provide an evaluation copy if you are up for trying it. The manuals are also online and there are also a lot of training movies that may give you an idea of its capabilities.
I really like the product (of course most people like the product they are using). A weak point may be the manuals. They sometimes are not very thorough at explaining how to use tools (the training movies make up for a lot of this). On the other hand, most routines are very intuitive and do not require manuals.
I am also very pleased with support. When I have found a bug after a new release, I have often received a patch within a few days.
Thanks for your response.
Your expertise is invaluable. Do you have any recommendations that will help aid us in researching our sofware options? We are mostly skeptical with the stormwater analysis application combinations.
Having run the tutorial on the storm pipe network design in Carlson Civil 2007, I anticipate it will replace Stormcad in my routine. The integration of Civil 2007 of design and drafting is quite impressive.
Hydrocad is so simple to use, I don't know if I will replace it...and ICPR is so sophisticated I don't think I'll replace it either..lol.
I basically use the hydrology package to compute stage storage and to do what if's with my pond designs.
The package is great for contouring and developing design profiles. I can grade out a road in minutes.
