External References and Copying Models
We have an API that opens a model (Assembly1.SLDASM) and copies it with it's dependents(part1.sldprt, part2.sldprt)to a different directory.  When I re-run the API to copy the model Assembly2.SLDASM with it's dependents (part1.sldprt, part2.sldprt), these parts will be referencing Assembly1.SLDASM.  Can anyone shed some light on this issue?
By the way, in between these copies we are CLOSING Solidworks! It seems as though Solidworks keeps parts with the same name in memory even after closing and rebooting.  Has anyone had a similar issue?
RE: External References and Copying Models
If you can post your code it might help.  You say the parts are still referencing Assembly1.  Do the parts have in-context references?
The original parts have in-context references to the assembly.  The copied parts have out-of-context references to the original assembly.
...It gets a little time consuming to try and strip it down to a macro.
Essentially, the code in Visual Studio is:
Dim DocList As Object = SW.GetDocumentDependencies2(SourceFile, True, True, False)
If Not DocList Is Nothing Then
  Dim SourceArray As String() = DirectCast(DocList, String())
  Dim SourceCount As Integer = SourceArray.Length \ 2
  Dim SourceFiles(SourceCount - 1) As String
  Dim TargetFiles(SourceCount - 1) As String
  For FileIndex As Integer = 0 To SourceCount - 1
    Dim CurrentFile As String = SourceArray(1 + 2 * FileIndex)
    SourceFiles(FileIndex) = CurrentFile
    TargetFiles(FileIndex) = Path.Combine(TargetDirectory, Path.GetFileName(CurrentFile))
  Next FileIndex
SldWorks.CopyDocument(SourceFile, TargetFile, SourceFiles, TargetFiles, CopyOptions)
Just found a workaround for this.  Wondering if anyone can explain why this works:
If you launch Solidworks and then close it inbetween copying the assemblies, it seems to clear out the memory and the references are OK.
Why would Solidworks have anything in memory after it's closed!?
Just a guess, but here goes.
Since SolidWorks will search several locations for files, it probably maintians a list of where it has found a file.  Since the old and new parts share the same name, it is probably opening the old part, with the old references, from the old directory.
Eric
I think it's doing something similar to that too.  Anyone know of a way to stop Solidworks from searching for these file locations?  Is there a temporary directory to clean out?  An option I can't find?
