PARENT VIEW.....POOOF!!!
SW 2006 sp4.1 ... I drop an assembly into a drawing, cut a bunch of sections out of it, add some balloons and such, do some zooming, etc... then after a while the parent view is missing, the section lines remain, but no edges or anything else. The only way I have found to fix the problem is to save and kill SW, open the dwg and it's fine... I've tried a force rebuild (Ctrl-Q) edit sheet format, and go back to sheet... anything else? What's the deal here?
Thanks!
Go Honda!
RE: PARENT VIEW.....POOOF!!!
So it sound like what I'm doing is all I can do... Thanks!
Go Honda!
None of those worked for me.. closing SW does.
Go Honda!
