What computer would you guys buy?
It's the end of the year and the tax man says I should spend some money. I currently have a Dell 670 with a Nivida 3400 card. Dell workstations have worked well for me.
Ok, no holds, go for it. What is your dream computer for SolidWorks (2007). Would a Dell 690 with a (very) high end graphics card be a good idea? What about the SLI graphics solutions?
Also, what are your opinions on 32bit vs 64bit for SolidWorks.
Give us your "Christmas" computer dreams.
RE: What computer would you guys buy?
Also thread559-163400
Chris
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 10-27-06)
For most SolidWorks users, the Dell 390 (similar) with a Core2 Extreme X6800 CPU and Quadro FX3450 graphics will be the fastest system on the planet. If you do a moderate amount of rendering and/or linear FEA, the quad core QX6700 might be a better choice.
If you work on *huge* assemblies and/or do *extensive* rendering/animation and/or nonlinear/fluid FEA and need more than 4GB of RAM, then move up to a Dell 490 with dual Xeon 5160s and 8-16GB RAM. (With 4GB RAM, the 390 is faster an cheaper, with more than 4GB of RAM, the 490 is MUCH less expensive.)
SolidWorks 64-Bit (x64) Version
http://youtube.com/watch?v=PDOf3IEr4FU
SW07 SP1.0
Flores
Based on these reviews, I've been responsible for three purchases at Xi Computer--by far the most bang for the buck among the tests done by Cadalyst. And I've been happy with the quick service and great performance of the systems.
I've preferred AMD's chips for the same reason, although a lot has changed over this last year--so you'll want to do your own research on what will specifically deliver what you need.
I do lots of renderings and animations (at least I do now). As a result, something with multiple processors/cores goes a long way to speed up the rendering, since all processors/cores will be used to their full extent while rendering. SW still uses (for the most part) a single thread while crunching model geometry, so in this case the fastest chip (single) wins. So it depends what you're doing. I keep a browser and email up while working, along with miscellaneous other processes, so I like having my dual-core AMD FX-60. Very nice for stability and quick performance.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe trumps reason.
ht
Chris
AutoCAD 06
DigitLife also did a nice comparison of Core2 Duo and Athlon FX processors that included ProE, SolidWorks and MATLAB benchmarks. http:/
