TB partnumbers won't delete
I've set up our toolbox with derived standards from ansi inch and metric. I then went through and using the Import feature in the Configure dialog box, I created all part numbers and descriptions for the commonly used fasteners. Somehow the user derived Ansi metric set screw, flat point has got 8-10 part numbers for each part number (exactly the same) despite the option being checked to only allow 1 instance of a part number in the entire toolbox. Further, I cannot delete any of these, neither through the Configure dialog box (as mentioned above) nor with the Delete Favorites button in the Property Manager while inserting the set screw.
How do I get rid of these? Any clue what the cause is? I've went through and deleted all Part Numbers and Descriptions for all set screws, but they still show up.
Craig Sink
Mechanical Engineer
Force Design, Inc.
RE: TB partnumbers won't delete
I couldn't get the Print Screen to work previously??? (It pasted in black & white). But I've got an image now that may clarify...
http://img93.imageshack.us/img93/7412/tbsetscrewhb3.jpg
Craig Sink
Mechanical Engineer
Force Design, Inc.
I guess noone wants to mess with toolbox...:)
Craig Sink
Mechanical Engineer
Force Design, Inc.
