Shaded with Edges not consistent thru drawing
I have Shaded with Edges selected for the view but some components have Edges showing like in Shaded only.
Resolving part does not change anything.
Any suggestions?
Andrzej
RE: Shaded with Edges not consistent thru drawing
Version of SW?
Computer Specs?
Video card and drivers used?
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
We run SW2006 SP4.1
HP Compaq dc7600 Convertible Pentium 4 CPU 3.60GHz
2.77GHz, 2.00GB RAM
ATI FireGL V5000
Make sure your display state on the part is not set to shaded.  A simple test is to set the view display to wireframe and see if the parts stay solid.
-b
is the driver the certified driver? For ATI cards you have to click on the VIew notes at the SW website to determine if they are the correct version.
regards,
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
I will check the driver but at least I understand it's graphic card issue not the SW bug.
Thank you all.
Andrzej
