Runtime Exception error when saving
My company just got the V5R17 release and after installing it on my laptop when I tried to save a Catia part file it said:
"Runtime Exception"
Click OK to terminate
Then Catia closes and the file which was saved cannot be opened again.
It's actually the first time this happens and I would know how to solve this problem. We had no problems on the other computers, only on my laptop.
RE: Runtime Exception error when saving
if you run the R17 software management tool - the results return compatible?  Laptop info please.
Derek
Hi Derek,
Check Integrity Level 1 & 2 was OK!
Prerequisites OK
Check Memory : OK
Check Network adapter : OK
Check DLLs : OK
MS Windows XP SP2
Intel Celeron x86 1.5 Ghz
1 GB RAM
The problem only occurs when saving and when opening "Document Properties" (File -> Document Properties). I can open and view my R16 files, but when I save them the the message comes.
Dxm06 - try this, make a backup copy of your job, run the tools -- utility -- CATDUA (Version R17).  Change the selected operation to clean from check.  As a general rule, you should wait until SP1 of a version (for production use).
Derek
It doesn't seem to work! =/
We're actually running SP2, and I installed SP1 + SP2 with same results.
