set "PID parameters" for power serie of y = 3E-40*x^18.94
How can I set "PID parameters" for the control of the system with the following "power serie" ?
y = 3E-40*x^18.94
X min = 30
X max = 90
PID parameters:
iMax,iMin,
pState,istate,dState,
pGain,iGain,dGain,
MAX,MIN
regards
RE: set "PID parameters" for power serie of y = 3E-40*x^18.94
What plant has such an extreme y=f(x)?
Going from x=30 to x=90 means zillions of orders of magnitude change in y. Are you sure you got that relation between x and y?
Gunnar Englund
www.gke.org
68.8 1.00E-05
73.7 8.90E-05
78.6 2.00E-04
83.5 6.40E-04
are some of points.
at main working area X is between 60 and 80
PH?
This a chemical reaction?
Keith Cress
You can often map the valve if things permit then run via a table that takes into account the actual flows that 'will' occur.
Or model the valve and run with the model in the 'plant'.
Keith Cress
but it will not work with LOOK-UP TABLE
- input is voltage for gas paffing valve control
- turbo vaccum pump run continuously
- output is vaccum
m777182
