im trying to make three holes on the round side of the cylinder
hi everyone..
this one is driving me crazzyyy!!!!
i have a cylinder and i want to make three holes on the round side of the cylinder (120 degrees apart). but everytime i try that, it only lets me place one hole on one side, but when i go to the other side to make the second hole, it turns the circle, which will make the hole, into the degree that the other hole was made.
its very hard to describe what i am trying to do..
so please add me to your msn so i can explain.
thanks a lot
missa
thanks a lot
missa
RE: im trying to make three holes on the round side of the cylinder
I had the same problem.
look for pattern cutout in help !!
divide in 3 (120 deg)
You have to set one and dimention it ,then aply
Because you set 3 (120 deg ), solid edge will do the rest for you !!
gr Anthony
anthony thanks a lot
you just made my day man :)
thanks a lotzzzzz
missa
doing good!! Already helping others...
Greets, IJsbrand.
