Expansion Joint Allowable Design Stress - High Temp
bellows material B409 AlloyH (NO8810)
design temp specified 1200F
a exp.joint manufacture has come back with a design temp of 1000F, allowable stress 14,400 psi, elastic modulus 24.2E6 psi.
using MatPro (paulin.com) I was able to obtain a yield stress of 7,400 psi @ 1200F, elastic modulus 23.2E6 psi.
Not being a metalurgist of expansion joint professional I am curious if specifying the design stresses calculated with MatPro would be unrealistic.
Does any one have experiences with this type of material application???
RE: Expansion Joint Allowable Design Stress - High Temp
Go to the web site below and download the Technical Publication on Alloy 800H/800HT. This is a comprehensive technical paper and provides actual material property data on elastic modulus and low cycle fatigue strength among other important items.
I would contact several more expansion joint suppliers nad have them provide you with an expansion joint material recommendation and design to evaluate. Having the above paper, you can verify material property inputs, and ask good questions.
http:
@ 1000 deg F 14 Ksi
@ 1200 deg F 7.4 Ksi
The above stresses are allowable stresses as determined by the requirements in ASME B&PV Code, Section II. At 1000 deg F, this material behaves time independent, meaning designing at or below this stress value will avoid failure from tensile overload, yield, creep deformation or stress rupture in service.
At 1200 deg F, time dependent properties come into play. In this case, the allowable stress is controlled by creep deformation (permanent deformation after so many hours in service). So, you need to remain at or below 7.4 Ksi in your design to assure remaining below 1% permanent deformation in 100,000 hours.
The specialitymetal document was most helpfull.
