Opening File, Sorted by Last Modified
When opening files in Solidworks (I'm still using 2005), does anyone know how make the the default view, the Detailed List sorted by Name? Everytime I open a file I usually can't find it because it's not alphabetical. I then have to click on the little icon next to "new folder" and change it from List (default) to Details, then click the Name header to sort. Is this a Solidworks issue or Windows? My file names are alphanumberic and not descriptive.
Thanks for the help in advance.
RE: Opening File, Sorted by Last Modified
As you wrote, go to detail view, select the "names" column to sort.
There may be a way to change this in Windows, but don't know right now.
Try asking in the Tek-Tips forums.
Chris
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 10-27-06)
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2006 SP5.0 on WinXP SP2
Eric
