Labview Timer
Labview Timer
Labview Timer
I want to trigger a timer in Labview 7.1 once a signal is sent to the computer and to stop the timer once another signal in sent (I don’t know if that can be done through the same data-acquisition channel) .  Immediately after that I want to store the elapsed time to make some calculations.
Is it possible that someone will help me with this or at least give me some tips?
Thanks in advanced. :)
lamantarraya
RE: Labview Timer
Do a state machine, assuming that Labview doesnt already have a component for that.  Did you look in the help file?
TTFN
RE: Labview Timer
I actually went to the help file, but I didn't find any timer that will reset after each exection.
I made a while loop sequence that works, but the problem is that it doesn't reset.
I've been trying but I haven't find a reset function.  Is just that I'm not a pro at Labview and believe me I have expend a lot of time looking into the help file.
RE: Labview Timer
I don't know about 7.1 but 8.0 has an event structure
and an elapsed time function.
 You can also do it with a loop structure and the
wait untill millisec.(function)then read the index
of the loop and multiply by the millisecond timer.
 As far as your while loop, If the condition is outside
the loop it will run once (ie. a button on the frontpanel).
Try putting it inside the while loop.
 Hope this helps
