FRICTION LOSSES IN PIPE FITTINGS
dcasto,
Thanks for your reply.But which of the equipments is each formulae meant for?.Also, you need to define the parameters Beta and Omega.(I have not laid hands on the TP410 and GPSA hand books)
RE: FRICTION LOSSES IN PIPE FITTINGS
equation 1 is for gradual contraction
equation 2 is for sudden contraction
There are another set of Crane equations for sudden and gradual enlargement (ie flow from small end of reducer to larger end)
Beta is ratio of small diameter to larger diameter
Omega should read theta
Theta is angle of convergence or divergence in enlargements or contractions in pipes.
If you wish to pursue this any further I strongly suggest that you obtain a copy of "Crane 410"
Hope this helps
Instead of starting a new thread to thank someone for a response on another thread, maybe try responding instead. This makes reading a bit confusing.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
