Fire Resistance
Fire Resistance
Fire Resistance
I have a project where we are trying to use an existing multi-wythe brick wall approximately 17'' wide as a 3hr rated fire wall.  Is there a numerical procedure for determining the hourly rating for a wall of this construction?  The wall is about 100 yrs old.
RE: Fire Resistance
Check out the procedures outlined in "Technical Notes 16B - Calculated Fire Resistance" published by the Brick Industry of America (http://www.brickinfo.org). It has a pretty good, and accepted, methodology for confirming that your wall is way more than 3 hrs.
RE: Fire Resistance
Chapter 9 of the IBC gives you prescritive data.
