Text Templates
Text Templates
I have several assemblies that I need to draw for drawing packs to release to a customer. The customer has a specific requirement as to the format of the part labeling they would like to see on the drawing. I am trying to automate the labeling process as much as psosible.
So far, I have been able to automatically create balloons with part numbers in them. I only need a portion of the number though, so that isn't enough for me.
I am also able to create a text template witht eh proper formatting for my drawings that will automatically populate the correct part number. Same problem as above.
I can automatically extract the proper portion of my string using a function. However, I haven't figured out how to do this within the text template.
Any help or suggestinos out there?
RE: Text Templates
Derek
RE: Text Templates
If I made the parameter part of the drawing, I would have to make a unique parameter for each of the text template insertions. That would take me more time than I'm saving.
