Flare Radiation
Flare Radiation
Hi Coleages,
I am searching for adecuade emisivity in the radiation
prediction.
API 521 RP use a emisivity of 0,3 but some
article of NAO Co say values of 0,13 maximun
why this diference? whats is the correct emisivity for
a emergency gas with MW = 120
prediction.
RE: Flare Radiation
Also, the type of flare is a factor. Sonic type flares are inherently smokeless and thus have a low emissivity. A conventional flare, especially at low flowing rates if assist gas or steam isn't being used could be very smoky (as the flaring rate increases, the high velocity gas exiting the tip entrains more and more air thus reducing the smoke and its emissivity value even without steam or assist gas though that's not to imply it won't be smoky).
Because of these factors, some companies limit the lower level of the emissivity to ensure that ground level radiation isn't excessive, especially during an upset (eg. steam for the flare tip may be in short supply). I've seen minimum numbers range from 0.3 to 0.4 explictly stating these limits over-ride vendor's 'expected' performance numbers.
If it was an inherently smokeless design, I'd be willing to go with the vendor's numbers after checking with some users. If it is a conventional tip, I'd be more concerned.
