Prompted Entry
Prompted Entry
Prompted Entry
Does anyone know how to re-order the prompted entry for a sketch/title block?  Every time I re-do my title block it scrambles what information it asks first.
RE: Prompted Entry
As far as I know, you can not change the order that it prompts you for information. That being said, you can either reorder the prompted fields manually or scrap it all and start from scratch. Sorry, I know this isn't the answer you wanted.
David
RE: Prompted Entry
There is a way, think back to Autocad and creating block attributes. What you need to do is open the sketched symbol and copy each item and then paste them back. the trick is to copy them in the order that you want then to appear. What this will do is paste them back in the order that you need them. Just make sure that you delete the old stuff before you paste them. Also you may want to look into using the iprop wizard awsome tool for this.
RE: Prompted Entry
Thanks Russell I hadn't tried that.
David
RE: Prompted Entry
Thanks!  I thought I was going to have to bite the bullet on that one! Everyone I work with thanks you guys.
