Unity Check button
Unity Check button
Unity Check button
While working with a model, I did something to make the "Unity Check" tab (under Postprocessing) disappear.  Does anyone know how to put the tab back or an alternative location for this informaion?  Thank you!
RE: Unity Check button
I am not sure but i think you should check the input file. you may have removed the 'CODE CHECK' comand.
