Photoworks 2007 mesh material
How do I create a new material in Photoworks 2007 similar to a mesh in which parts of the material is removed? I'm trying to create a slot pattern in a rendering without adding the slot pattern in the model.
Thanks in advance
Chris
Thanks in advance
Chris
RE: Photoworks 2007 mesh material
An alternate to saving the mesh bitmap with transparent pixels is to save a bitmap of your mesh in a high-resolution file and subtract out the pixels you don't need by color within the PhotoWorks dialog when applying the mesh as a decal.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe trumps reason.
