A material that can only receive tension ???
Hi Everyone,
I need to model a material that can only receive tension (not compression), i.e. thin-plastic like material. Do you know whether that kind of material is available in the library of Abaqus ?
Thank you in advance for your suggestions.
regards,
Sendy.
RE: A material that can only receive tension ???
can't u just use a material with zero tension strength?
Hi hamadadf,
I need to have tension, not compression. When I look at the material library, it seems that I can't find the material which provide zero compression and only tension.
Do you have/find that kind of material model ?
Thank you.
Sendy
I wasn't aware that Abaqus had a library of materials, however there is a *no compression option to be used with *elastic.
corus
Hi corus,
I mean materials model which are provided in Abaqus manual.
Thank you for your post, it is exactly what I need.
regards,
Sendy.
