thru curve mesh help
I am having trouble making a domed surface. The surface is supposed to look like an egg split in half lengthwise. I have curves defining the outside oval shape and curves defining the front and side profiles. What command do I use? In NX2, I would use 'thru curve mesh' to pick the outside primary curve and a point where the front/side profiles intersect. Then choose the front and side cross curves to make the surface. In NX4, it won't allow you to choose a point. What am I doing wrong?
RE: thru curve mesh help
SS
CAD should pay for itself, shouldn't it?
