DUMB FILES
DUMB FILES
DUMB FILES
Do you guy know how to convert solidworks files in to dumb files. Essencially a dumb files is file that cannot be section, measured, and modify. I need to convert an assembly, and some componets.
RE: DUMB FILES
All models files can be "sectioned, measured, and modified" if you have the right software.  The only way around this would be to send an image file (jpeg, gif, etc).
You can remove your feature info if you save your files as parasolids or some other neutral file format.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
RE: DUMB FILES
There are many options under "File Type" when you save the file such as IGES, STEP, Parasolid, etc.  However, what the end user can do with the "dumb" solid will depend entirely on what software it is loaded into.  Most CAD packages can measure, but not modify, "dumb" solids.
RE: DUMB FILES
What about an eDrawings file?  Those can still be sectioned, but they can't be modified or measured.
RE: DUMB FILES
I save the files as IGES, STEP, and Parasolid, but I can still measure the model.  I want my customer to not be able to measure my solid.  By the way when I save a file as STL I cannot section it, or measure it, thats what I'm looking for but the only problem is that I cannot save an assembly as STP only components.  Also, what is a STP file?
RE: DUMB FILES
Save the assy as a part file. Then open the part file and save as a .stp file.
Chris
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 10-27-06)
RE: DUMB FILES
I save the ASSM as a part file, when I try to saved as STL it say "geometry invalid."  But when I save an ASSM as Part file it does not let me section and measure the moded.  That what I want, I think it changes the features to surfaces.  Thanks, now is there a way from my costumer to change the assembly save as a part back to and assembly or be able to measured. I hope not.
RE: DUMB FILES
Why do you need to give them cad geometry if you don't want them to be able to do anything with it? It sounds like you should follow handlemans suggestion. Save as easm and uncheck all the options (the ability to export as stl and the ability to measure the files). Edrawings is essentially like low resolution .stl polygon files. This tool is the perfect tool for what you are looking to do.
RFUS
RE: DUMB FILES
but with edrawings they can still section my model.
RE: DUMB FILES
In that case, why not publish it on 3D instant website?
RE: DUMB FILES
how do I publish my model.
RE: DUMB FILES
You can not change the part back to the assy file.
When you save as a part, select the box "Exterior faces".
The 3D instant website will be good.
Chris
AutoCAD 06
RE: DUMB FILES
Juanmedina, please read the following page at SolidWork's website:
3D Instant Website
RE: DUMB FILES
Thanks guys for all your help.
