Lifting Lug Calcs using Compress
I have to carry out lifting lug calcs. The lifting lug is on a valve train i.e. attached to hollow square bar on a skid.
Thanks in advance
RE: Lifting Lug Calcs using Compress
COMPRESS provides option to design lifting lugs for vertical lift, and also lugs for lifting/turning vessel (including the tailing lug). See the options under the "Attach" menu.
The lifting lugs are attached only to the pressure boundary material (eg: heads, cylinders, cones). Tailing lugs can be attached to support skirts.
COMPRESS does not provide option to attach lifting lugs to structural supports such as skids, etc.
Please write to us at support(at)codeware.com if you have further questions.
Tom Barsh
Codeware Technical Support
When will COMPRESS ADD THE FOLLOWING TO LIFTING:
Regards to Scope of Supply
Deliverables for the scope of delivery includes the following:
-Hoisting Cover and Tailing Lugs Including Hoisting Facilities.
REQUIREMENT BY GLOBAL SOULTIONS
If compress does not support lug calcs, then how can I carry out calculations for the lug. Is there a method or program that I can use.
I have used method of EN 13445-3 16.7. Its programmed in Visual Vessel Design (www.ohmtech.no)
