Compatability of zinc and aluminum as bearing material
I have a low speed application (less than 5 rpm) in which I'm need to use a zinc casting for the bearing material and aluminum for the shaft (.50").  Can galling occur between the two with or with out lubrication?  Loads are less than a 4 ounces.
