Export of co-ordinates and attributes
Is it possible to export the co-ordinates of a block along with its attributes to the same file. (or seperate files easily combined).
I have a block which contains names of property which are home to septic tanks (very interesting I know) and I want to extract the information (along with the evelation and depths which are also stored as attributes) so the names of the property sit alongside the co-ordinates of the centre of the tank in the output file.
Cheers. Sean.
RE: Export of co-ordinates and attributes
The answer is it is possible. The ability to do what you want is not totally built in though. You may need to program parts of it. Attibute extraction is in the Express tools. Block insertion points will need to be pulled.
"Everybody is ignorant, only on different subjects." — Will Rogers
Problem is after obtaining the co-ordinates they then have to be matched to each respective extracted attribute (which contains the property name). I've noticed that when you extract or export the attributes from a block theres a column called 'handle' defined individually for each block in a '34d6 type format.
If I can extract the coordinates at the same time as obtaining that handle value, it would be easy.
Any idea where the handle comes from / is stored for a block (or is it individual for each attribute extraction.)
You suggest programming - thats where I slip up. Do you have any code which does just the extraction of co-ordinates?
Cheers. Sean.
When you say coordinates, do you mean the insertion point of a block? You might also want to post a sample of the block somewhere where we could take a look at it.
Thats correct (the insertion point which represents the centre manhole). Where / how do I post the block?
Cheers. Sean.
You can mail to me at borgunit2003%ignoreme%at%yahoo
extracting x,y,z coordinates for blocks is a very easy process using eattext. you can extract attribute and general block properties to an autocad table or excel spreadsheet.
Wonderful for the attributes - I'd forgotten about eattext, but no co-ordinates - am I doing it wrong?
Cheers. Sean.
Answer to my own question - yes I am doing it wrong - just fill the xyz fields for extraction.
An extra question though. Can the table be edited and the blocks updated from those edits (rather than the blocks being changed and the table updated from them - much quicker)
Cheers. Sean.
