Boron Steel for Grade 5 Bolts
Is 10B21 Boron Steel acceptable to be used for Grade 5 Bolts? Where can I find the specification for this?
Bagyo
Bagyo
RE: Boron Steel for Grade 5 Bolts
Thanks for your input. I received grade 5 cap screws from our supplier and when I checked the Material Test Report, the products were made from 10B21 boron steel but the head marking is still with grade 5 not 5.2. The products passed the mechanical testing equivalent to grade 5 as per SAE J429. Do I have the right to reject the products because they were not designated appropriately?
Thank you
Cory
The replies from swall and CoryPad are both correct. The bolts should have been identified as Grade 5.2 and you do have the right to reject them based on the improper identification. Whether or not you want to do this is a topic for another discussion.
