Duplicate areas not filleting the same on a part
How come I can fillet (1) section of a part & the same exact type of section on the same part will not fillet?
RE: Duplicate areas not filleting the same on a part
If I think what your are saying ...
you have two areas that are the same type of geometry, but only one will fillet?
Try making the fillet much smaller to see if it works. If it does, your fillet won't work because of geometry constraints.
Can you show a pic of the areas?
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 10-27-06)
Is it a multibody part? You cannot fillet between multibodies.
If it is a single part, are the adjacent corners suitable to continue the fillet?
cheers
