Manufactured to Purchased Drawings
My company has a hard time keeping the Purchasing and Manufacturing departments from changing the status of drawings after they are released from Eningeering. They will change a manufactured part to a purchased part, but the drawings never get flaged to change them to VID or SCD. Or Purchasing will find a new vendor that was not listed on the VID... or will change vendors from what was specified on an SCD.
How are other companies managing this issue?
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
RE: Manufactured to Purchased Drawings
I have always just used part numbers on the BOM's/PL's for purchased parts, and drawings for manufactured parts.
Purchasing should NEVER have control to change ANY engineering drawings.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 10-27-06)
Why have drawings for Purchased parts? We are a manufacturing company, making 90% of our own components. The other 10% is hardware, bearings, electrical connectors, etc. Due to volume of required parts, or capacity on the manufacturing floor, components are sent outside to be manufactured for us.
Chris
AutoCAD 06
My last place had a large machine shop but sometimes due to work load parts were outsourced. They still manufactured to our drawings, essentially the parts were identical regardless if made in house or externally.
We left it up to manufacturing purchasing which way they wanted to do it.
The standard of drawing was the same even if we knew in advance it would be outsourced.
Only if design control were being transferred to the vendor would I expect you to need to make them into a SCD/VCD, or am I missing something. I thought an SCD/VCD was only used when you didn't control the design (ie drawings)?
Now in terms of changing vendor to an unapproved source this is a quality issue that should be enforced through qualtity audits. If you have any approvals FAA, CAA, ISO 9001 this should probably be part of you system.
If the part comes in to print, why do you care where it came from?
The "or equal"s for COTS parts is another issue. You need a process to ensure engineering review of any non-qualified suppliers' stuff to ensure that it really is equal.
I understood VCD to mean you have no control over the design, and SCD meant you have total internal control, at least to the point that the component is critical enough that it must be obtained from Source X, not Y or Z.
VID/VCD... these are used for COTS (commerical off the shelf) components. I'm not too concerned about them. The Scource Control Drawings are another matter. Purchasing in their all encompassing quest to purchase the
cheapestleast expensive components will haggle and brow-beat vendors so badly, they will "cut corners" to get our account.I know my company
is crazyis ill-runis disorganizedisn't perfect, I just didn't realize it was unique in this case."Art without engineering is dreaming; Engineering without art is calculating."
Our copy of ASME Y14.24 (I think that's right) has gone missing so I can't check but I don't think you have full control with an SCD, at least in so much as you don't control the whole drawing pack. It is typically an outline drawing defining only critical dimensions/requirements and listing approved sources of supply with their details for an item which a vendor supplies but to your specific requirements.
Taking an example of a 'black box' specially designed for you an SCD would probably define the envelope, mounting/interfaces and inputs/outputs. It wouldn't detail what was in the box. This could change completely so long as the dimension and input/output remain constant.
Now in terms of deviating from the approved sources of supply for SCD this is a quality issue and I would have thought they would deal with it as I posted before. I'd only expect Engineering to get involved if purchasing want to formally qualify a new vendor, and this of course should happen in advance not when the first (or perhaps 2nd or third) batch of parts gets there which it sounds like is happening.
Do you have a quality department at your place? We have one at my current employer but they seem to have defined quality differently from what I was used to in aerospace/defense
Purchased parts only have to meet the requirements set forth in the SCD, and purchasing should have the option of getting the best product for the money, provided the source is approved.
Jim Sykes, P.Eng, GDTP-S
Profile Services
CAD-Documentation-GD&T-Product Development
www.profileservices.ca
John Nabors
"Against stupidity the very gods themselves contend in vain." - Friedrich von Schiller
The ECN process controls these changes. All vendor drawings; be they word drawings or descriptions in a BOM need to clarify "or engineering approved equivalent.
Revision levels control this. I see this all the time; you purchasing and manufacturing departments need to order parts not only by numbers, but by revisions.
For example, order part number 1234 "rev G".
This is the ONLY way an engineering department can retain the integrity of the design.
It needs to be clarified at the top of the management chain.
Purchasing, sales and marketing all have the ability to request a change. They do so bi filling out a Engineering Change request. This may be a design change or a change to approve a new vendor for an existing part.
Engineering researches the ESR. If it is approved, then Engineering issues an Engineering Change Notice. The change notice includes recording the change, who requested it and why.
The drawing and/or BOM is changed and assigned a revision number. Copies of the ECN need to be recorded by purchasing, manufacturing and sales.
Revision levels are always called out on drawings. Purchasing is responsible for making sure all vendors and/or manufacturing departments have the correct revision levels. Manufacturing has the responsibility of making sure work orders have the correct revision levels.
Charlie
www.facsco.com
Could you clarify this, as it is opposite what I have experienced as good drawing practice. There is at least one thread in this forum addressing this issue, and the concensus seems to be that component rev levels DO NOT belong on an assy drawing.
--Scott
http://wertel.eng.pro
I don't think that is exactly what was determined in that thread. Yes, revision of individual components does not need to be reflected in the revision level of the assembly drawing but an assembly drawing still needs a revision level on the drawing in order to track drawing specific changes such as changes to notes. Different configurations should be controlled by part number but a new part number is not necessary for a typo correction.
David
Chris
SolidWorks 06 5.1/PDMWorks 06
AutoCAD 06
If there is another thread on assemblies, can we leave it over there and not bring it in here?
Charlie
www.facsco.com
I agree. Assembly drawings, like other drawings, do show a revision status. I infered from FACSs post that all component revision levels should be on the assembly drawing, which is what I took issue with. Upon re-reading of the post, I see that I read it wrong, and that part drawings are indeed the subject. My apologies to everyone for misdirecting the thread.
