Print Screening
Print Screening
Print Screening
For some unknown reason when I plot a map form my computer with the appropriate linetypes I get a incorrectly screened map, whereas if I use an associates computer to plot the same map (with the same settings as near as I can tell) the map comes out right.  Does anyone know of a setting that could cause this?
RE: Print Screening
Check your associates DIMSTYLE setting when plotting.
"Everybody is ignorant, only on different subjects." — Will Rogers
RE: Print Screening
Thanks for the response.
I should have mentioned that I am using Land Desktop 2005.  I don't see a DIMSTYLE setting - where can I find it?
DIMSTYLE sounds like it may pretain to dimensions -  what does it do?
RE: Print Screening
My mistake. I meant PLOTSTYLE. If it is like AutoCAD, you expand the plot dialog with an arrow at the lower right.
RE: Print Screening
Turns out I was using an old driver.  The IT guy got it squared away for me.
Thanks for the efforts.
