Losing Detail Views
Losing Detail Views
Losing Detail Views
I have an ongoing problem with some detail views in assembly drawings.
When I open a drawing the first time, the model in the detail view is blank, but any annotations remain - if I switch from outlines to hidden lines, the view returns, and I can switch back to outlines and print.
Any thoughts on why this occurs?  Is there an easy fix I'm missing?
RE: Losing Detail Views
Hey, no fair, your cheating!  You gave the "fix" before the problem.  smile Usually the question is "I opened a drawing and the views are missing.  The dimensions and annotations are there, but the model isn't.  How do I get the view back?
There are 5 or 6 threads with the above question, but this reply doesn't help you.
Flores
