text box perform a GET request?
I need to  take the data from the text box, perform a GET request on google using the text, and then parse the results.
example: I want to type into a text box from a form and it enters a query to google(using google as an example) for feedback into a datagrid.
thanks
RE: text box perform a GET request?
I would first suggest that you look at the URL of a Google Result Page, such as the following:
http://www.google.com/search?hl=en&q=Internet+Transfer+Control&btnG=Google+Search
which does a Google Search with the terms "Internet", "Transfer" and "Control".
Then, you can submit that URL to the Internet Transfer Control to load that page into your application.
The key is using the Internet Transfer Control.
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
