POTENTIAL ER... ADD "STICKY POINTS" TO LIMIT MATES
Let me run this by the real experts before I submit an ER.
Would you like to have "sticky points" added to limit mates?
For example - I have a rotating dump bed for one of my trucks. Id like to see the bed rotate +/- 90 degrees from center while "sticking" at 10 degree increments. At the same time I want it to dump from 0 degrees to 80 degrees & "stick" at 10 degree increments also. Sure - I can almost do this with multiple configurations. But all the possible combinations of configs makes this un-realistic.
Is there an existing way to do something like this that I've overlooked?
Is this worthy of an ER?
Windows XP / Wireless Intellimouse Explorer
SolidWorks 2007 SP1.0 / SpaceBall 5000
Lava Lamp
www.Tate3d.com
Lava Lamp
www.Tate3d.com
RE: POTENTIAL ER... ADD "STICKY POINTS" TO LIMIT MATES
Or are you wanting the part(s) to stick/snap/hang slightly when being dragged?
Either way it sounds like it could be useful in some situations.
Lava Lamp
www.Tate3d.com
My work-around was to create a sketch that had the stop points visible. It's not accurate, since nothing will exactly snap into place, but it's good enough for the rough needs of camera placement in animations.
I think you should submit that as an ER. However, you'll probably want to think up a solution as to how the snap would work. Would you have to un-click and re-click to move past the snap? (Etc.)
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe trumps reason.
I envision a tendancy to stick on the snap point untill you pull it away... But un-click & re-click would probably be simpler code... also just as effective.
I'll submit the ER & reference this very thread while I'm at it...
Lava Lamp
www.Tate3d.com
I always thought real work was somethng that got your hands dirty. Come to think of it, my keyboard is kind of grimy right now.
RFUS
You're working WAY to hard pal...
Lava Lamp
www.Tate3d.com
Lava Lamp
www.Tate3d.com
RFUS
I'll try that on my assembly... thanks for the suggestion.
Lava Lamp
www.Tate3d.com
I don't really use emoticons either, but rock on doctor!
RFUS
