Mobius strip...how to?
Another rookie question.
I have SW98 and have been trying to model a mobius disk without any success. Has anyone done that before?
Thank you.
Thank you.
RE: Mobius strip...how to?
Check out this site for your strip.http://www.zxys.com/swparts/
I hope that helps,
Scott Baugh, CSWP
credence69@hotmail.com
fist pick the Front plane and sketch a circle.
On the top line construct two separate rectagular sketches each with a contruction line corner to corner and a pierce relation between the midpoint of the construction line and the circle in sketch 1 orient the rectangles so that they appear parallel (on the long side) with circle.
On the RIGHT plane, create two more sketches with the same diagonal contruction line pierced to the circle. have thes sketches appear perpendicular to the circle.
Create the loft by picking each section at a corner,pick the corners of each subsequesnt section in a fashion that showns the proper "twist" to create the desired effect.
Hope that helps
Jon
