PCB heating element
PCB heating element
PCB heating element
I have a Fuji/intersleeve shrink sleeving machine which has a PCB heating element used to heat splice the pvc sleeve material when changing rolls.  Does anyone know of a manufacturer of these types of PCB heating elements?
RE: PCB heating element
I have never heard of a "PCB heating element".  Where's a picture?
Keith Cress
PTC heating element?
Gunnar Englund
www.gke.org
All,
I don't know if I am using the right terminology.  It looks like a printed circuit board to me, but brown not green, and instead of a conductive layer, it is a high resistance layer, with just a contact at each end.  I'll try to get a picture.
Kieth,
Exactly, just rectangular.  I'll try them. thanks.
Richard
Then, you have a foil heater
TTFN
I assumed foil is thin and flexible, the one I have is maybe 1mm thick and rigid.  Is it still called foil?
IRstuff that was weird.
 Your post was NOT there but rlee53's was.  So I did the Minco thing.  Now I come back and there is a 'new post' before rlee's... Yours.. Most strange.
Keith Cress
no problem, I don't automatically assume poaching. winky smile
TTFN
Thanks to both you guys.
That picture looks more like a thick film heater on a steel substrate. I used to work for a company that made 'em. That one is probably destined for a kettle.
  Sometimes I only open my mouth to swap feet...
rlee53
But is it an orangish substrate with copper foil etched on it?
TTFN
