catia drafting
catia drafting
Hi
How can i select all dimensions in one sheet only? i tried using search but it selects all dimensions in all sheets.
thanks
rkhan
thanks
rkhan
RE: catia drafting
to limit your search to dimensions in one view, use the ADVANCED tab in the Search panel.
Try a search query like this:
Drafting.Dimension&
Drafting.View.Name=FRONT
RE: catia drafting
select the sheet in which you want to select the dimensions.
use advanced search and use "from current selection" in the look field.
this selects only the dimension in the current selection which is "sheet.x"
