Stiffness of a curved plate
I am doing a small analysis on a curved plate (like a pipe cut off in radial direction) designed to resist impact loads, but I have been unable to find the stiffness for such an element.
It is welded to support beams in one.
RE: Stiffness of a curved plate
However, as you reference impact loads, if you have plastic deformation and eventually the collapse of the arc, then this is a problem that should be treated by tests.
prex
http://www.xcalcs.com
Online tools for structural design
