Failure criteria for Composite beams.
Hello, 'm abit new to this forum and I would be glad if some one would answer my question.
I am doing some elastic stress analysis on composite beams, and I am new at this, I am not so sure of which failure criteria is best to apply. Personally I feel that Rankine and St. Venant(Maximum principal stress and strains)is out of the way.But then 'm not too sure which of the other three ( Tresea, Hencky and Von misses, and Beltrami& Haigh) is best for complex elstic failure analysis.
RE: Failure criteria for Composite beams.
Dik
There are a number of failure criteria for composite sections and one of the most common is the Tsai-Hill formulation which is probably most like the Von Mises criterion.
Qshake
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
Dik
The most common in my experience is Maxiumum Strain. It is the opinion of many in aerospace that this is all you need...
Any comments would be appreciated.
SWComposites (Aerospace),...I am using Glass fibre Reinfroced Plastci (GFRP) and I am looking at two beam shapes specifically.
1.Box beam 2. I-shaped Beam.
I am particularly investigating their Elastic coupling and not so sure what failure critieria to use to examine the beam when it fails due to the bending-twist or strech-twist coupling.
