Had a client send a Point Cloud created in SW
with scan to 3d, but how can we use this geometry as points? It will not allow us to select the points to drive curve geometry.
RE: Had a client send a Point Cloud created in SW
Do a search here for "point cloud".
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 10-27-06)
Have you tried creating a spline in a 3D sketch?  You can place spline curve points on the points floating in space to get what you need--at least roughly.  It takes time, but ought to work fine.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all.  And awe trumps reason.
With the Scan to 3D use the Mesh prep wizard and follow each step it will mesh the point cloud data.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
