Compatibility with Class 125 Thru-Bolted Flanged Butterfly Valve
Are all Class 150 flanges compatible with a Class 125 thru-bolted butterfly valve, where the valve does not have thru-bolt holes? Obviously, I'm asking about flanges with the same NPD as the valve.
If not, what determines which Class 150 flanges are compatible with the butterfly valve, since no driling template is applicable?
RE: Compatibility with Class 125 Thru-Bolted Flanged Butterfly Valve
The PCD and dimensions are the same as Class 150
