Sensor Systems S65-5366-1S Connector Type
Hello
My company purchased Sensor Systems S65-5366-1S blade antennas for use on our robotic aircraft. The vendor's spec says it has a type 'TM' connector. I found a reference in thread247-45264 that called it a type 'TN' connector. But I can't find a mating connecter anywhere for either TM or TN. Does anyone have experience with this antenna or know to what connector TM/TN refers?
It's larger than SMA but smaller than TNC.
The RF engineers here are stumped and the vendor so far has been less than helpful.
Thank You.
Refs:
http://www.sensorantennas.com/pdf/5366-1C,1030,1S,31S,71S,30,60,72S.pdf
