UPS don¦t start
UPS don¦t start
Hi.
I have 2 UPS´s heads (TrippLite´s Datacenter 5000) that just refuses to start when I conect it to my 220v L6 receptacle.
Both heads work fine in other instalations, but in this one in particular don´t work.
Of course, I had tested the receptacle and, as far as I can see, everything is fine. 2 110 phases and 1 neutral. The voltage doesnt drop when I try to start the UPS´s heads, but the indicators of the heads don´t even light (it is supposed to ligh on when you plug the cable to the AC line).
Do you have any idea of why is this happening?
Thanks a lot.
Thanks a lot.
RE: UPS don¦t start
dydt
RE: UPS don¦t start
2. Make sure the units are locked in to each other(control and battery) or they will not start and will not show any LED indication
