Aerospace Grade Cable
Hi!
I am searching for a cable that is 1 inch long and used to transfer no more than 1W power between the ends. The application is for aerospace and hence requires high reliability besides being exposed to continouse vibration . The cable is on plane fuselage, protected mechanically by housing from direct hit, but is exposed to deicing fluids and negative 60 deg C temperatures.
I am looking for cable manufacturer who has made cables for similar applications. Any leads would be highly appreciated.
Thanks in advance.
Thanks in advance.
RE: Aerospace Grade Cable
http://www.timesmicrowave.com/
http://www.picwire.com/
http://www.ecsdirect.com/
http://www.emteq.com/products/aerospace/index.cfm
