Water network modelling
Hi is there anyone who could advise me regarding the proper assigning of numbers of nodes in water network modelling? Is there a sequence to be followed or steps like a loop maybe in clockwise or counterclockwise? I am using epanet and watercaed software. Pls advise. . .thanks
RE: Water network modelling
As long as your system is logical and can be understood by others, you should be fine.
Geoffrey D Stone FIMechE C.Eng;FIEAust CP Eng
www.waterhammer.bigblog.com.au
With modern software you have more options as francesca noted. If you want shorter labels than "street x street" you could always number your nodes based on a map grid. For example…several of our clients have utility base mapping with a grid overlay. A typical grid might be 500 feet x 500 feet and be indexed something like A to M east-west and 1 to 25 north-south. Within grid square F10, you could label the nodes F10-05, F10-10, F10-15, and so on.
