Moisture issue in EVA process
Hi All,
during manufacture of an EVA based masterbatch, a smell of acetic acid is noticable ( I assume this is a result of hydrolysis?) Are there any additives available to mop up excess moisture from the raw materials that we can use during the process? Or any other way to reduce the production of acetic acid during the process?
Thanks in advance
Thanks in advance
RE: Moisture issue in EVA process
