dimension for reducing tee - radius between run & branch
Does anybody have a cut sheet for stainless steel 304, butt welded reducing tees? I need the radius for the transition from the run to the branch in a 3" x 1½" SCH 10S tee (MSS SP-43).
If I can show that there is actually a radius, then I can reduce the pipe entrance flow loss in my pressure drop calculation.
Clyde
Clyde
RE: dimension for reducing tee - radius between run & branch
jt
Thank you for the detail technical link
If I can use a r/d of at least 0.02 for a 3"x1½" reducing tee instead of assuming a square edge, my RV inlet piping pressure drop calc will drop from 4.6% of set pressure to 2.7% (which satisfies the <3% guideline). When I get this radius measured, I will post up the results.
Looks like I will be leaning on this forum more in the future.
Clyde
